07-08 Acura TL Type S 4 pot brembo on s2k?
Hey all, I was stuck in traffic yesterday and looked over to my left to see a 08 TL with oem 4 pot brembo callipers. Our rotor diameters and thickness are virtually the same. Why has nobody done this conversion to an S2000? Way more affordable than Spoon callipers or a BBK and i've heard that the bracket bolts unto the s2000 knuckle.
I've been looking everywhere online to find an s2000 with this but to no avail.
I think there is a V6 accord brake caliper swap thread around here with tons of info, maybe that will kinda help....Here you go
Just to get an idea Good luck!
Any insight to the OP would be much appreciated
it looks like fastbrakes.com used to sell a kit https://www.s2ki.com/s2000/topic/463...ura-tl-type-s/
Putting the TL-S calipers on stock sized rotors seems pointless to me (just like the Spoon calipers), if you're going to upgrade your caliper you might as well spend a bit more and get a bigger rotor in there
I saw the thread you linked here, however there is no real useful info in there. the link to the fast brakes site doesn't work, and navigating their site is just coming up with blank pages for me.
Reapur the TL's wont work on the S2K for the simple fact that the pistons are staggered incorrectly for our vehicles. The brakes on the TL-S are mounted towards the front of the rotor while the S2000's callipers are rear mounted.
A larger diameter piston should always follow the smaller piston. If you were to use TL-S Calipers, you would have uneven pad wear since the stagger would be flipped on our vehicles.
You should also remember that the rotor diameters are not equivalent. S2000 = 300 mm while TL-S = 310 mm if I remember correctly. Furthermore, the offset of the TL-S Rotor hat is very different from the S2000 rotor.
My good friend has an Acura CL with the Nisin calipers. He has a lot of brake warp from the car. He replaced rotors 3 times with pads all three times and still has the same problem. Now he's looking into NSX calipers. I like the idea of the TL Brembo calipers but someone would need to do a DIY. Will they clear stock AP2 rims?
