2 questions about ohlins road and track
The front shocks have so much travel before they touch the bumpstop that its crazy. More than stock, in fact. So preloading the front isn't necessary or recommended. If the shock has too much travel, it won't control excess roll...and the tyre will strike the inside of the fender before the shock will complete its motion.
The rears, however, have very limited compression travel. So using some preload helps.
Instead of compressing the springs 2mm as Ohlins installation spec,you compress another 10mm -15mm before installation <rears>.that's preloading springs.
Same as any coilovers.
explains all you need to know here>
https://www.s2ki.com/forums/s2000-br...nside-1166830/
Ohlins have adjustable lower perch so use that for desired ride height.
'preload' is a somewhat misleading name. When the shock is removed from the car, tightening the collar up indeed compresses the spring more, adding 'preload' to the spring. But when you place the shock into car, and drop it off the jack, cars weight will spring will still compress to the same total as before you added preload.
So preload doesn't compress spring any more when in actual use. What it does do is raise the car (which if you have adjustable lower mount, you'd adjust away back to desired right height.)
The purpose of preload is to manipulate suspension travel vs droop. In the case of Ohlins, the rear shock body doesn't have an external resevoir, which means the gas bladder has to live in shock body, meaning shock is a bit longish.
That means there isn't a lot of room for suspension travel. Adding more preload gives more travel. But there are limits. The lower rear mount is also longish, so there are limits how much raising from preload you can take back out with the lower mount. There are optional extra cost lower mounts for Ohlins from value added resellers with a shorter design. This allows adding sufficient preload, yet still dropping to a lower ride height.
Another option is stiffer rear spring, so not as much preload is needed.
beefystud
05-03-2019 01:24 PM
usmarinedelta
10-02-2015 07:42 AM
stolitonic22
08-27-2008 12:51 AM
Chris S
11-03-2006 11:46 AM
