350z rear brakes
350z rear brakes
has anyone looked into if these could be fitted to our cars? i really dont know how hard this could be but these brakes can be had for dirt cheap and the rotors are vented. i know the lug pattern is the same as ours so the rotors should ? fit.
Standard. 4 piston. Brembo.
There are at least 3 different front rotor sizes. I kinda assumed at least 3 different rear rotor sizes.
lol...and I kinda lumped 370Z's in there too...which would create more options (my bad).
my car is a track only car. i was just wondering how come the s2000 shops havent looked into these vs the expensive options i see from each shop. 350z has 3 rear options , 2 that are single piston base (small rotor) 07 single piston (bigger rotor) 03-08 brembo 2 piston (biggest rotor) . all of these are still better then a s2000 rear plus all have ebrake connections .
In 350Z land:
Track and Brembo are the same caliper for an 18" wheel
there is also an 18" non Brembo caliper
and there is also a 17" non Brembo caliper They have no 17 " Brembo option
So all total there are 3 front wheel Z calipers
350z track 03-08 Brembos fit under 17s , I have 3 350z track buddies
All 350Z parking brakes are in the drum...not the caliper, as far as I can tell.
Your S2000 spindle/hub doesnt have those provisions.
That's the big reason companies aren't using 350Z/STi/EVO/etc brembos or larger sliding calipers from other cars for a cheap rear upgrade.
How does the NSX parking brake work? If its in the caliper...maybe NSX rear rotors and calipers are a cheap/easy upgrade.
Edit: it looks like NSX's have calipers with integrated parking brakes. And (relatively) bigass vented rotors.
