4 pistons RL calipers MOD
you can't use 350z rotors because the center hole is smaller about 67mm. I think we need about 70.3mm. The RL rotor would work if you have a spacer between the knuckle and the rotor. If you just use the RL rotors without the spacer, it will be rubbing against the tie rod end ...
