.7" vs 1" Drop
.7" vs 1" Drop
So I'm debating between Swift sports & Eibach ProKits and after doing some research I'm kind of leaning towards the Swifts. I just wonder if the extra drop on the Eibach's would be noticeable to the eye or if I won't tell the difference. I like the drop of the Eibach's but I hear the Swifts would be better for the track. Any input would be appreciated.
What shocks will you be running with them? Swifts tend to be the more popular choice between the two when one wants to lower and not sacrifice too much performance in handling. Before worrying about which springs are better for the track, do you actually track your car?
It depends on the car, but for the most part this rule holds true. Lowering springs are generally not an improvement in handling with stock shocks.
People often times will change out the springs with shorter and stiffer springs and call it sporty, but in reality, that just throws everything off. The concept of a great performing car is one where all the components work in symphony.
If you were to only plan to daily drive your car on the streets and never drive it beyond 6/10's of the car's abilities, then lower springs would probably be fine for you, but if you do plan to take it out to the track in the next few months, I would suggest taking it stock once or twice to get a feel for the car to determine exactly what you expect out of it before altering it's personality, as it could end up causing you to spend more money in the long run to re-alter everything again.
No problem. What part of the US are you from? There's going to be a lot of great track day events happening this year in the SoCal/Arizona region. Some of the best registration prices I've seen in the last few years too.
