ABS Code 54-1 "abs fail safe relay" after Rywire brake tuck
What did I mess up?
cleared it with a Snap On but immediately came back.
Can anybody give me some info on this?
Did a Rywire ABS tuck
Deleted the air pump and it's wiring (possibly deleted something that went to ABS on accident?
Tucked the wiring harness into the fenders and had to lengthen one ABS Speed Sensor (passenger side)
What gives? I don't think I did much wiring to tuck the harness... I think I may have had to lengthen a few grounds. Hard to say for sure because I did it months ago but haven't driven the car since then due to expired registration. I don't remember anything being difficult wiring wise
Does anyone have a trouble flowchart for this code?
So I looked it up. Honda has no flowchart for this code. If you get the code you're supposed to replace the modulator.
I replaced the module. Cleared the code.
And immediately after starting the car back up the code came back.
I checked the wiring and turns out I did no wiring whatsoever except to extend one wheel speed sensor connector. And this connector checks out as okay.
What gives? This is driving me nuts.
KYS2000
07-09-2003 06:10 PM
