The Actual S2000 Suspension Motion Ratios
Another good application of the data is to find the relative effects of different spring rates vs anti-roll bar rates. Generally the anti-roll bar rates are quoted at the endlink, by converting both to the wheel you can directly compare the relative effects of each. For instance, if you like the balance of your car but want to increase the stiffness of the front springs, you can calculate how much front bar needs to be removed to maintain the same roll stiffness. Ultimately track testing is always required to dial in the setup but these calculations can help avoid having to repurchase components which can get costly quick.
__________________
SAKEBOMB GARAGE > Click here to contact Us
Check some of our most popular products for the S2000:
- Ohlins DFV Billet Lower Mount
- Rear BBK RX-8 Caliper Conversion
- Front BBK AP Competition
- Setrab Oil Cooler Kit
Possible to get this stickied by a mod? We've had a number of people PM us looking for the link and name who were having a hard time finding the thread
__________________
I combined the OEM Spring Rate chart famously created by TwoHoo's, with the motion ratios and wheel rate formulas from this thread, and created a chart that adds the oem wheel rates for each iteration of the S. It can be found in thread below. I want to add the Total Wheel Rate (spring and swaybar rates combined), but not sure how to do that. Assistance appreciated.
https://www.s2ki.com/forums/s2000-br...-818884/page3/
__________________
Ultimately I want to create a spreadsheet that can be hosted online (looking for a site to host it), where you can mix and match components from different years, or aftermarket components if you know the spring and swaybar rates (and maybe even a swaybar rate estimator that asks diameter and if its hollow or not to give some kind of rough spring rate estimate), and it calculates your wheel rates for spring, swaybar, and total, and also tells you what percentage of front vs rear bias your setup has.
Of course it would just be a starting point, only real trial and error can find the best setup. But it could help a lot of people understand their current setup betrer, and where they should next make changes, and in which direction.
Chassis Dynamics and Suspension Tuning Consultation - SakeBomb Garage LLC
__________________
