Affordable Front Sway Bar Stiffness
I've done some searching but can't find any definitive rates. I found a lot of xx% stiffer but stiffer compared to what year S2000 bar (they change every 2-3 model years)?
I'd like the stiffness rate or at least which bar is the stiffest from the following: Eibach Whiteline Cusco adj and non-adj Or any other affordable bar. Thanks. |
(Copy and pasted from another post)
S2000 Eibach Sway Bar rates: Front: 32mm Adjustable (HOLLOW) Pos.1 - 65 N/mm (368lbs/in) Pos.2 - 73 N/mm (416lbs/in) Weight - 4.8kg (10.6lbs.) Rear: 29mm Adjustable (HOLLOW) Pos.1 - 90 N/mm (515lbs/in) Pos.2 - 106 N/mm (605lbs/in) Weight - 4.9kg (10.8lbs.) I was able to search the forums for OEM sway bar specs for comparison: OEM S2000 Sway Bar Information: AP1 100 series- Front sway bar part number: 51300-S2A-003 28.2mm (HOLLOW) with a 5mm Sidewall Rating at 61.6N/mm Rear sway bar part number: 52300-S2A-013 27.2mm (HOLLOW) with a 5.3mm Sidewall Rating at 73N/mm AP1 110 Series- Front sway bar part number: 51300-S2A-J01 27.2mm (HOLLOW) with a 5mm Sidewall Rating at 53.6N/mm Rear sway bar part number: 52300-S2A-013 27.2mm (HOLLOW) with a 5.3mm Sidewall Rating at 73N/mm AP2 120 Series- Front sway bar part number: 51300-S2A-013 26.5mm (HOLLOW) with a 4.5mm Sidewall Rating at 46.6N/mm Rear sway bar part number: 52300-S2A-J01 27.2mm (HOLLOW) with a 4.5mm Sidewall Rating at 67.6N/mm 130 Series- Front sway bar part number: 51300-S2A-013 26.5mm (HOLLOW) with a 4.5mm Sidewall Rating at 46.6N/mm Rear Sway bar part number: Do not have 25.2mm (HOLLOW) with a 4.5mm Sidewall Rating at 51.6N/mm |
Thanks yeah I believe I've seen that. I have a 2000my and if I get an eibach bar it would only be as stiff as my oem rear bar. I'm looking for something a lot stiffer but affordable. Anyone got specs on the other cusco or whiteline?
the whiteline is about halfway between OEM and the saner bar on soft its decently stiffer
I think its 28mm solid steel |
Whats your budget?
I'd say less 200. Whiteline seems like a good one so far. 187 shipped on ebay too. It's actually 30mm but yeah solid nonadjustable.
Get a AP2 rear. I am running a AP2 rear with a Eibach front. It is money!
Did you decide on which bar to get? I'm in the same boat.
Saner Front
OEM SWAY BAR 295.5 LBS SOFT SETTING 566.0 LBS CENTER SETTING 644.0 LBS STIFF SETTING 739.3 LBS |
Yeah I know what the Saner rates are but its not even available anymore and its not exactly affordable.
Oh, I'm probably going to go with the whiteline bar. |
