stopteck bbk oem wheels
make a long story short... ups damaged my rotors and calipers. filed a claim.
now i have new rotors... and my06 specfic brake lines from stoptech... which i had to custom order. i also had new spacers made from the wheeladaptor.com... which they made on the spot.
now everything works.
i have a clearance of 1.5mm-1.8mm from spoke to caliper. stoptech recommends 2mm.
some other guy on here has a wheel clearance of... 1 creditcard? which is give or take 1 mm.
i like the firmer feel of the new setup. braking is also more consistant.
oh and weight savings... not as much compared to the wilwood units... rotors save about 1lb - 1.5lbs each side... caliper... save about 3lbs? i forgot.... ill have to check.
ill update more later.
you can use 16. but i use 17mm just to be on the safe side. since matt @ stoptech recommended 2mm of clearnace between the wheel and caliper.
regardless i like the way the s2k handle with the wider track. rear doesnt kick out as much.
i would highly recommend any s2k, especially ap1... to add spacers... to widen their track..
