Bearing installed backwards?
Got my rear knuckle back from the shop and am wondering if the wheel bearing can be installed backwards/upside down. According to Robinette's site, the rubber seal needs to be facing up. That said, looks like the shop installed it backwards and am wondering if I need to by another one or if this still viable. Safe to run or trash and replace? Hub has not been pressed in yet.
I'm really curious to know why it is important that the bearing face with the rubber towards the hub.
I have disassembled them, and the quantity and diameter of the balls are the same on both sides. Some manufacturers use metal seals on both sides. And I would have thought facing the rubber towards the hub would expose it to more heat.
Is there really a difference, or do we just do it that way because that's how Honda did it?
Dude.......you need to visit Harbor Freight and get a shop press.........be done with it, no more visits to get stuff like this done.
RedCelica (08-24-2017)
Subscribe to the Harbor Freight email coupons because they are better than the mailer and store fliers. I see the 12 ton press for $99 quite often (almost always). I think the 20 ton gets down to $129.xx on occasion, but you've got to be on the lookout for this price.
I have the 12 ton and it has successfully changed 8 bearings, but it struggled on a couple. I had to use a heavy hammer to break some free. I had to do the freezer/torch trick to get a few of the inner races off the hub. Even then the 12 ton was barely able to get the job done. In some cases I had to push the handle quickly to spike the pressure as the fluid slowly squeezed past the pressure relief valve.
I think using all 20 tons to break free stuck parts would be terrifying and possibly break stuff. So, I'd still use the freezer/torch trick or hammer on stuck parts, but the 20 ton press would allow me to apply a little more force without the sudden spikes that can be more terrifying.
In summary, if I had time to plan ahead, think I would wait for the 20 ton to go on sale and pay the extra $30.
