Better brakes with AP2V2 wheels?
#21
Do you all think there is any need to use anything other than stock brake components for folks that are driving 100% street?
#23
If u track often say once a month, One peice rotor will crack no matter wat kind or brand u get. I have fist hand experience on this. Ur car is super charged so it's gana crack even faster. That torax kit u guys r talking about iv never heard of so idk about that but I wouldn't wana risk brakes for any unknown brand for brakes. When u loose brakes on track, u never felt this alive in ur life. Plus putting a 6 or 8 pot caliper on OEM sized rotor speeds up the cracking process of the rotor. I have tried the spoon calipers with spoon rotors. Cracked that rotor in 30 min. To keep ur oe wheel and have great RELIABLE breaks is hard. Maybe try wilwoods dynalite kit with 2 peice rotors. But idk bout the fitment. The brake ducts do help but they help the pad out more than the roter imo.
#25
I'm going to be going with the Acura Legend GS calipers. I have the exact same issue, I really like the AP2V2 wheels, they look perfect on the car, so I don't what different wheels, but the clearance is very tight on them
They're really made for single sided calipers.
The Legend GS calipers are a two piston style with two pistons on the inside, so they're have no issue clearing. They are also supposed to be a bolt-on if you have the right bracket, and should work well with the 28MM Acura NSX front rotors. I think the Odyssey and a number of other Hondas also run 28MM rotors.
Here's a link to swapping them on a 6th gen Accord. Note, lots of people swap the 6 gen accord calipers on the S2000, so these should work. The Legend GS calipers are also really cheap, like $100 a piece, and will give same clamping as a 4 piston calipers. They just don't cool as well, but with a thicker rotor, it should give a tremendous improvement. I still need to get the exact size of the pistons, but I think the Legend GS calipers will work very well with the Sakebomb Rx8 rear caliper conversion.
Piston sizes:
Legend Calipers 42mm and 38mm piston sizes.
NSX Calipers 40mm and 34mm piston sizes.
The Legend GS brake swap information thread - 6th Gen Accord DIY and Performance Forums
http://www.preludepower.com/forums/s...d.php?t=343434
Here's what I could find for piston sizes:
S2000 Spec's
Caliper
Piston Size: 54mm
Front Piston Surface Area: 2290 mm^2
Weight: Approx. 9.5lbs (Loaded)
Rotor
Diameter: 11.8"
Width: 24mm
Bolt Pattern: 5x114.3
Hub Size: 70.3mm
Height: 39.6mm
06 RSX Type-S Spec's
Rotor
Diameter: 11.8"
Width: 25mm
Hub Size: 64.2mm
Height:46.99mm(47mm)
91 NSX Spec's
Caliper
Piston(s) Size Front: 40 mm and 36mm
Piston Size Rear: 42mm.
Weight: Approx. 12lbs Unloaded (Caliper + T28 Bracket, Info from Televator)
Rotor
Diameter:11.1" inch
Width: 28mm
Hub Size: 70mm
Height: 35.9mm
98 NSX Spec's
Caliper
Piston(s) Size Front: 40mm and 34mm
Piston Size Rear: 48mm.
Rotor
Diameter:11.7" inch
Width: 28mm
Hub Size: 70mm
Height: 36mm
94-95 4DR Legend GS Spec's
Caliper
Piston(s) Size: 42mm and 38mm
Front piston surface area: 2520 mm^2
(I believe this is correct, same numbers show up in about 5 different sites, and stamped on piston, )
http://www.acura-legend.com/vbulleti...-systems-2971/
Weight:
Rotor
Diameter: 11.1"
Width: 28mm
Hub Size: 70.2mm
Height: 47mm
-- rear piston is 38mm on Legend GS.
-- evidently the rear is also 38mm on S2000. The RX8 rear caliper looks like its 43mm. This means the rear area on S2000 is 1134, and RX8 is 1385. That's 20% larger than the S2000.
That means that the Legend GS dual pistons have 10% more piston area than the S2000. So to fit the LegendGS you definitely need more rear brake area.
Factory S2000 ratio is 2290 / 1134 = 2.01
With the Legend GS calipers up front and RX8 in the back, this becomes 2520 / 1385 = 1.747, but Legend GS up from and factor in the rear is 2520 / 1134. = 2.22.
I just don't know if using the Sakebomb RX8 rear kit even with the Legend GS calipers will give too much rear brake bias.
What's interesting is the 97 NSX went to a huge rear caliper piston size, which looks like it gave it a huge rear brake bias shift. I don't know if they compensated for the much larger rear caliper with a different proportioning valve.
Piston sizes:
S2000 Spec's
Caliper
Piston Size: 54mm
Rotor
Diameter: 11.8"
Width: 24mm
Hub Size: 70.3mm
Height: 39.6mm
Rotor
Diameter: 11.8"
Width: 25mm
Hub Size: 64.2mm
91 NSX Spec's
Caliper
Rotor
Diameter:11.1" inch
Width: 28mm
Hub Size: 70mm
Height: 35.9mm
98 NSX Spec's
Caliper
Rotor
Diameter:11.7" inch
Width: 28mm
Hub Size: 70mm
Height: 36mm
Caliper
Weight:
Rotor
Diameter: 11.1"
Width: 28mm
Hub Size: 70.2mm
Height: 47mm
#26
Would
Piston sizes:
DIY: How to install two-piston Acura Legend calipers - Honda Prelude Forum : Honda Prelude Forums
S2000 Spec's
Caliper
Piston Size: 2.0"
Rotor
Diameter: 11.8"
Width: 24mm
Hub Size: 70.3mm
Height: 39.6mm
Rotor
Diameter: 11.8"
Width: 25mm
Hub Size: 64.2mm
91 NSX Spec's
Caliper
Piston(s) Size: 34mm and 36mm (I believe this is correct.)
Rotor
Diameter:11.1" inch
Width: 28mm
Hub Size: 70mm
Height: 35.9mm
98 NSX Spec's
Caliper
Rotor
Diameter:11.7" inch
Width: 28mm
Hub Size: 70mm
Height: 36mm
Caliper
Need info about the brake/caliper systems. - The Acura Legend & Acura RL Forum
Weight:
Rotor
Diameter: 11.1"
Width: 28mm
Hub Size: 70.2mm
Height: 47mm
Would
Piston sizes:
S2000 Spec's
Caliper
Piston Size: 2.0"
Rotor
Diameter: 11.8"
Width: 24mm
Hub Size: 70.3mm
Height: 39.6mm
Rotor
Diameter: 11.8"
Width: 25mm
Hub Size: 64.2mm
91 NSX Spec's
Caliper
Rotor
Diameter:11.1" inch
Width: 28mm
Hub Size: 70mm
Height: 35.9mm
98 NSX Spec's
Caliper
Rotor
Diameter:11.7" inch
Width: 28mm
Hub Size: 70mm
Height: 36mm
Caliper
Weight:
Rotor
Diameter: 11.1"
Width: 28mm
Hub Size: 70.2mm
Height: 47mm
#27
I don't know, the Corvette seems to stop just fine from 170 MPH+ with two piston calipers, and it's a heavier car that the S2000.
I am definitely planning on the Legend GS 2 piston up front and the Sakebomb RX8 in the rear, but I won't be able to get to it for some time, I've got zero time at the moment.
The guys at Sakebomb said they could provide a custom proportioning valve to set the rear brake bias.
#28
#29
http://en.tarox.com/
#30
FWIW....................After I installed front brake ducts into my car in 2001 I tracked my car giving instruction or just lapping for at least 3 days per month for 6 years at numerous tracks around the mid-west and only cracked one rotor at Road America.
Tarox designed the kit that I use especially for the S2000 in both a 16" and 17" OEM wheel fitment configuration in conjunction with the European S2000 owners group. You will see it discussed on this forum most frequently in the UK forum. I think that their kits have been out there for more than 5 years.
Tarox | High Performance Brakes
