Bilstein PSS (and possibly PSS9) height and ride quality
I've recently installed Bilstein PSS coilovers, and have been playing with the ride height a bit. Something I've noticed is that there is a substantial difference in how smooth the ride quality when you set it at or right above the maximum recommend height. For example, if the rear is set 10mm higher than the maximum (max is 215mm, so 225mm, about a 3 finger gap) and the front is at max (345mm, about 3 finger gap also) it rides very smooth. My guess is it has to do something with preloading the springs since there is no adjustable preload normally. My question is, would I be likely to damage the suspension at all by running it a bit higher than it's max height spec?
I can't see how it'd damage the damper, and like yessamgerg mentioned, your ride quality is getting better because you're getting away from the bumpstops and giving yourself much more bump travel. The PSS/PSS9 springs are very soft, so you need this travel to not be riding hard on the bumpstops at all times.
And as as far as the ride height at a 3 finger gap, I think that's pretty close to the stock ride height. Probably just a tad below. It's about 4" from rim to fender if that helps. I didn't measure the stock distance before I installed the Bilsteins, so if anyone knows the stock suspension distance from fender to rim top on an AP2 I'd appreciate knowing too.
I just went out to garage and measured.
My '06 has its stock suspension. 130k miles, if that has any indication of possible sag over time and use.
My garage has a decent amount of slope, but for this purpose I think it should be level enough.
The wheels are stock. Tires stock sizes and new (not that tires should have any real impact here).
Gap, rim to fender, as measured to fender metal itself (fender liner and rear lip rubber are not included in these measurements.):
Front: 5"
Rear: 4.75"
Front: 5"
Rear: 4.75"
As another data point for you, I recently measured ride height for my stock '06 w/97K on an alignment pad. Measurement taken ground to the furthest forward / rearward points on the frame rails. Results:
Left Front: 4.875" Right Front: 5"
Left Rear: 5.125" Right Rear: 5.25"
Front: 5"
Rear: 4.75"
Front: 5"
Rear: 4.75"
UK Moderator
Here's how to measure ride heights from the service manual, it may be of some help:
FWIW, I ran the rear ride height slightly above the maximum recommended by Bilstein on my PSS9s with no problems at all over 50k miles.
I'm a big fan of the PSS and I am very sensitive to overly harsh rides and definitely sensitive to any bounciness. To me the PSS is the perfect coilover system for my setup, the ride is superb. I have to double check my measurements but I am about 1.25 inches 1 lower than stock, maybe 1.5 to 2 finger gap, and I couldn't be happier, with the ride quality. I have a 2002 ap1 and I honestly find the PSS ride better and less harsh than stock, and zero bounciness, it is very refined. I would never switch back to stock. I find it to be very compliant.
Most people buying coilovers look to lower the ride a bit, so I don't know anyone who is increasing the height above the recommended spec. I would double check your installation as the ride should not be as you describe with that coilover system IMO. That sounds odd.
