Notices
Brake/Clutch Fluid Color
Old 01-28-2010, 04:47 PM
Liked 0 Times in 0 Posts
Default Brake/Clutch Fluid Color
I was reading some posts on here and decided to check my brake and clutch fluid. Do you guys think they need a change?
Thanks in advance for any helpful input.
Clutch:
Brake:
The brake fluid one is not the best, I'll try to take a better one of it tomorrow.
Thanks in advance for any input.
czech09 is offline
Old 01-28-2010, 05:25 PM
dammitjim's Avatar
Liked 13 Times in 4 Posts
They both look like vomit.
They are clear when they are new. I would change them both.
If that 2000 is new to you I would recommend changing all the fluids unless you have a receipt showing some of them were done recently.
dammitjim is offline
Old 01-28-2010, 05:44 PM
[QUOTE=dammitjim,Jan 28 2010, 06:25 PM] They both look like vomit.
czech09 is offline
Old 01-28-2010, 07:15 PM
nickp's Avatar
i would upgrade if your gunna do brake and clutch fluid ate or motul
nickp is offline
Old 01-28-2010, 09:58 PM
IF they are turning dark "fast" that means you're on your way to a leaky master and/or slave cylinder. I think the reason it changes color is because the seals start to fall apart/dust gets in/etc. Most likely your car was like mine: not driven often til you purchased it, so now that you drive it more often, the corrosion and seals are wearing all at once...
its not a hard job, at laest. go to MajesticHonda for cheap parts!
ahrmike is offline
Old 01-29-2010, 09:44 AM
Slows2k's Avatar
Liked 77 Times in 77 Posts
Moving to new Brake forum
Slows2k is offline
Old 01-29-2010, 01:26 PM
Liked 41 Times in 30 Posts
Do we have a brake bleed DIY?
rob-2 is offline
Old 01-29-2010, 01:36 PM
dammitjim's Avatar
Henwee
04-10-2015 06:25 AM
B.Money
06-12-2007 11:42 PM
anthonys2k
04-18-2006 02:39 PM
Gernby
11-01-2002 05:51 AM
Quick Reply: Brake/Clutch Fluid Color
Contact Us - Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service
© 2019 MH Sub I, LLC dba Internet Brands
