Brake pad recommendations
FWIW, I've gotten similar or even better track performance out of off-the-shelf DOT4 (Valvoline, Pennzoil) vs. ATE SuperBlue. But in any case, if the car's not going to be tracked, brake fluid isn't likely to be an issue as long as it's reasonably fresh.
Carbotech bobcats, used Hawks and hated them on my subaru, then switched to carbo's and fell in love. I will be replacing stock with the bobcats when my oem pads are done.
Originally Posted by bigmacnfries,Jan 18 2010, 04:42 PM
stock not enough? it should be even with an 'aggresive' driving style..
Originally Posted by nismo4life,Jan 19 2010, 01:41 PM
I only got to put about 700 miles on the car before the brakes started to rub metal on metal.
wut
Carbotech FTW
Originally Posted by Hero,Jan 19 2010, 07:37 AM
unless you're tracking the car, go with oem ap1 pads and a better brake fluid like ATE.
try search for there
axxis ulitmate
HP+
I was going to ask something similar after having my brakes fade quite scarily again tonight. The "private" road is all downhill and very twisty, all 30-130kph stuff. It may be my driving style, but i try my to brake late or aggressively or ride the brakes, but after 10 minutes the brakes get to the point where you wouldnt wanna trust them. The smell tells me theyre getting hotter than they should...
Your Solution:
New Stop-Tech Street performance Pads
http://www.centricparts.com/index.php?opti...=article&id=178
