Brake upgrade effects on bias
scroll down to bottom of https://www.spoonsports.jp/philosophy05.html
Both added.
Question for anyone using Wilwood calipers that use a 7416 or 7420 pad, would you measure the height of the pad material at the pad center? Wilwood and others spec it at 43 mm but when I measure from the drawings, it looks more like 39 mm. It's not a big deal because it only changes the bias by 1 percentage point, but would be nice to know which is correct.
Only pad height matters. We're using piston area as a proxy for force and the torque applied is independent of the area of the pad. Pad height matters because it affects the effective radius of the rotor. I'm assuming that the surface of the pad is evenly distributed above and below the midpoint of the pad. That's not going to be accurate for some pad shapes, but the impact is small as you can see by my question above.
https://www.wilwood.com/Calipers/Cal...12003-BKPiston 1 Bore (in)1.38Piston 2 Bore (in)1.12Piston 3 Bore (in)1.12Total Piston Area (in²)3.46
What would the brake bias be with the Wilwood front and rear kits installed? Rear kit: https://www.wilwood.com/BrakeKits/Br...emno=140-10310
__________________
My For Sale Thread: JDM and OEM parts
Have you looked into the Alcon 4 piston, Endless 6 piston or Project Mu 4/6 piston front kits?
__________________
No, I went with the SBG Wilwood front kit + URGE rear rotors which was reasonably affordable and yet also able to handle the track. Hence I stopped looking at new kits. There was so much misinformation on how bias changed when i started looking and it doesn't look like there's been much improvements from the BBK suppliers yet either. So if you or others send me the links to the pages, I'll be glad to update the spreadsheet.
I have a kit that I would like you to add to the spreadsheet:
https://endless-sport.co.jp/brake_ca...000_index.html
Disc size: 324mm
I got piston size from here:
https://endless-sport.global/au/products/caliper_a/48
34mm and 41mm
pad size ?:
https://endless-sport.co.jp/products...RCP/RCP153.pdf
Disc size: 324mm
34mm and 41mm
pad size ?:
Disc size: 324mm
34mm and 41mm
pad size ?:
Disc size: 324mm
34mm and 41mm
pad size ?:
Also it's just one 4 piston caliper with 2x 34mm and 2x 41mm pistons. Please update the sheet with piston #1 as 34 and piston #2 as 41.
