Broken HKS rear damper adjustment tool
Yup, straightforward but as mentioned, PITA.
In addition to the 3 8mm bolts where the fuel door is, I think theres another bolt in the trunk that holds it.
Once those are out, you push the neck in - takes quite a bit of force
i have a small hand, I dont think I need to remove the filler neck. The problem is the rear coilover has a small metal pin on top of the hole where you insert the hex key in. I can’t remove that pin
