buddy club N+ coilovers adj.
Originally Posted by driftintherain,Jan 28 2008, 09:01 PM
how do you like it?
There is much better out there but if your gonna run hard on the street and auto x time to time, these would be perfect for you!
If your gonna auto x A LOT, consider b/c pro or a better suited coil over
Originally Posted by z4k,Jan 30 2008, 05:20 AM
What are the spring rates? Got pictures? Where did you buy from and how much?
Suspension adjustability is a key element when selecting a top quality coil-over system. The N+ SPEC DAMPERS are designed to accommodate a wide range of driving conditions from regular roads to prepared racing surfaces. Dampening settings ranges from hard (+4kg/mm) to soft (-4kg/mm).These kits will also include urethane isolated upper pillow-ball mount. The urethane isolating ring keeps suspension noise to a minimal while maintaining the precision feel of a solid mounted strut.
Originally Posted by mph2k,Jan 28 2008, 10:31 PM
i just got a set of buddy club N+ coilovers, just wanted to know what the knob on the bottom of the strut does, is that for rebound?
^ I don't recall there being a knob at the bottom of my N+ coilovers to be honest. I know there is the threaded shock body with the lower portion being adjustable for height without affecting spring pre-load. Also I know there are knobs at the top of the shock for dampening adjustment. But I don't recall another knob at the bottom. I'll have to check next time I am up on jackstands.
FromaDB2toanAP1
03-21-2011 04:20 PM
