Camber kit
Camber kit
Hey guys, I currently changed my coilovers to buddy club n+ dropped the car. I got new tires cause the old ones were worn out due to having camber. I just bought new tires and in need of a shop close to Pomona CA. That can install a camber kit? Also what's a good camber kit that I should use? Daily driver. Would like to get this fix over the weekend.
The car has factory camber adjustment.
Depending on how low the car is, you should be able to get back in spec unless something is worn or bent.
For 100% street driving use, up to about -2 to 2.5 deg of neg camber won't hurt anything.
Fix your toe to factory spec. Also adjustable with stock adjusters.
Camber doesn't kill tires, toe does. Make sure you have 0.0 toe up from an .20 toe max rear. -2.0 camber is fine, but you'll want less up front. Our cars come stock with adjustable camber, like B said.
