Car pulls to the right when braking, only sometimes. Ideas?
Not often, but sometimes when I brake the car pulls to the right pretty forcefully. Before and after alignment and brake check. I got a UK spec alignment done and had my brakes checked by my Honda mechanic and he says the brakes look fine and are wearing evenly. The car is lowered with BC Racing coilovers, is it possible a slight height difference from either side of the car would cause this? Any other ideas?
Edit: Tires are inflated properly and worn evenly as well..
May look fine but a strip down and grease the pins are a must as well as getting rid of the rust build up on the pad sliding area to give a little clearance for heat expansion ect.
The rears should be done also to eliminate any problems that end.
Air pressure is fine, thanks though!
