Carbotech bobcat pads versus oem?
Does anyone run the carbotech bobcat pads?
I'm wondering how they compare with oem pads on the street, especially since they cost twice as much. I'm thinking about running these pads because the compound is compatible with their xp10/xp8 track pads.
Thanks
Thanks
Originally Posted by macr88,Jan 30 2010, 05:04 AM
I don't have them on my S but do have them on my Camry with stoptechs. I don't think they're worth the money.
Just swap rotors or run ax6 or xp8's
SO, if your looking for something for DD that is compatible with the track pads they sell, just get bobcat. when i wear these out i am going bobcat.
xp10s on the street? Yikes.
They suck until they get hot, IMO. And you can't get them hot enough on the street.
Anyway, I think I still have a set of partially used Bobcats from back when I used to drive the car on the street.
Danny at Carbotech said that using my oem pads on the street and xp10/xp8 for track on the same rotors is fine. I was surprised...and happy since oem is good enough for me a cheap.
I am getting ready to do my first track event in the S. I have done numerous events in my old Subaru, and a couple events in a spec miata. I currently have stock suspension and brakes on the S. I will be getting some Star Specs before the event. Do you guys reccomend just upgrading my fluid and bleeding the brakes, or should I really consider doing pads and fluid? I have been able to smoke my oem brakes under some hard canyon runs, so I imagine once on the track where I can really push the car, I will def be cooking my oem stuff. Note the track is not a very fast course, and only has one moderatly hard braking zone. There should be ample time to cool the brakes off between zones.
Based on a couple of posts, sounds like using my OEM equip. and just swapping brake pads will be ok for the track day. I would/will run the XP10/8 combo.
