Choosing a Harbor Freight Shop Press
Harbor Freight has a sale on a shop press this weekend along with a 20% off coupon, so I thought it might be time for me to pick one up. Turns out HF has two presses that are nearly identical and I seem to remember a discussion where one was considered to be a better choice than the other. Unfortunately search is no help. Here they are:
https://www.harborfreight.com/12-ton...ess-33497.html https://www.harborfreight.com/12-ton...ess-60604.html Can anyone help with how they are different and perhaps recall the discussion about which one is the better choice? |
You couod also read the reviews on HF site. They are often decent reviews by knowledgeable people that can help a lot.
Those two you linked to are the exact same thing
They are different item numbers so there's probably something different about them. Plus, as I said above, I recall a thread where one was identified as being better than the other, but alas I don't remember what the difference was. The reviews are a bit inconclusive: the bottom link scores a little better, but not by a significant amount.
HF does that a lot. Same exact product, different part numbers. Same Exact.
I don't think there is any trickery intended, just something internal on their end where that somehow came to be. |
I brought a 10 tonne press, thought that would be fine for what I need, but I found out when doing a rusted in wheel bearing that 10 tonne wasn't enough,,,,,so my advice is to get the 20 tonne if you can stretch to that. |
Originally Posted by DanielB
(Post 24455357)
https://www.harborfreight.com/12-ton...ess-33497.html https://www.harborfreight.com/12-ton...ess-60604.html Can anyone help with how they are different and perhaps recall the discussion about which one is the better choice? Get the 20ton for like $40 more, dude. |
The working distance and width between channels is different between the two according to the specs.
Originally Posted by Carbon S2K
(Post 24455658)
Thanks everyone. I read the fine print on the coupons and it looks like HF no longer allows stacking. I don't have a burning need for the press at the moment so am going to wait.
When I do buy it I guess it will be a 20T. I'm still a bit awed that 24,000 lbs (12T) isn't enough force to press out a bearing though :) |
Originally Posted by Car Analogy
(Post 24455553)
I don't think there is any trickery intended, just something internal on their end where that somehow came to be. Personally, I have the 20 ton. Works well. |
