coilerovers for approx $1,200
$1200 is a tough price point to improve on the OEM suspension. The factory KYBs are that good. I have spent plenty of time on my Koni/GC combo to know what they can and cant do compared to OEM. First I will say there are compromises, you give a little and get a little. Ultimately I would say they solve more problems then they cause so they were worth $1200 to me. I wanted some ride height control (preload), stiffer springs for tracking and adjustable damping to fine tune. The Konis actually have a working functional adjuster, and damping changes can be significant. You can get them to work with a range of spring rates.
I have gone faster with my Koni setup then the OEM suspension. However the delayed response of the Konis is noticeable compared to the sharpness of the OEM shocks. OEM shocks feel sharp but are actually too linear in my opinion and tend to get loose over rough pavement. Pick your poison...
There is a reason I am eyeing up Ohlins like many others.
I would assume Konis would make the car easier to drive.
I thought the stock shocks were made by Showa? I swear I've seen Showa stamped/written on the body somewhere.
My buddy on stock PSS9's is pretty effing quick. Not sure how the PSS is valved. But...comfortable doesn't mean slow.
The PSS9's are well damped...and while the Öhlins have room to support more mods, they're not inherantly going to make a stock S2000 any faster than one on PSS9's.
Originally Posted by dc2-2-ap1
To the comment of Bilstein PSS, they are great daily/comfort coilovers, but not great for track.
Used CR would be better than most other choices in this range. Koni with the right springs are probably the only new choice.
I just can't get behind the PSS9 adjuster. Id it won't deliver consistent changes on a shock dyno I would rather have no adjuster. At $1200 its:
Koni/GC
PSS
CR/GC
