Coilover Theory 101: Coil Spring Comparison
Just a model number and an abbreviation (in German) which is front and which is rear. Many, including myself, have hounded them over the years, but they refuse to divulge, citing no industry standard means to spec a single numeric spring rate value for a progressive spring. So if one tried to compare their spec to some other progressive springs specs, it would be misleading. They kinda have a point.
I even tried to just ask them what the percentage difference was front vs rear, no dice.
Anyway, I finished my measurements and published my findings in a new thread I just created.
Instead of creating multiple spring rate threads, you should add your info this thread. That will keep everything in one place.
Good stuff. If you are taking requests, I would be interested in seeing Eibach coil springs tested. I installed higher rate Eibachs on my KW clubsports because of ID clearance. I originally was going to go with Swift, but their ID was a little too small.
Would love to see Intercomp test data on the OE (Showa) S2000 springs! If you could validate (or refute!) my analytical models (see sig) I think it would be a great service to this community. I'm also curious what you think of the OE spring quality and whether they are susceptible to any substantial sag or rate fatigue.
Oh, and while you're taking requests, would you happen to be able to divulge the nominal shear modulus of Swift's spring steel?
Definitely would like to see the comparison between swift and other reputable brands.
Its good that you showed the differences between super junk springs and Swift. I think that's a good demonstration that a spring isn't just a spring, regardless of cost.
But it would be nice to see how/if/why Swifts are worth the premium over other reputable brands like Eibach, H&R, etc.
Regarding the shear modulus, the common 9254 silicon spring steel is around 78 Gpa. I'll check with the Swift technician, but not promising if they're willing to divulge or not
Based on your testing, you predict that wear rates are uneven between the Swift and the cheap Taiwan spring. I'm curious to see how it would compare to other name brand springs.
For Ohlins, a recommended upgrade is to buy a stiffer spring for the front and move the front spring to the rear, if a Swift spring was used in the front and the OEM Ohlin spring was moved to the back, might the wear rate be different between the two, which would lead to less than optimal performance from the coils?
Thanks for doing this!
Awesome info! I would like to see how Swift compares to other name brands as well. In addition to the brands named above, I'd like to see a comparison vs Hyperco, since those seems to be a brand which is selected when someone "upgrades" springs on an existing coilover.
