Sponsored by: Sake Bomb
Coilovers comparable to KW V3's?
Old Sep 14, 2010 | 05:19 PM
  #21
GrandMasterKhan's Avatar
i am also curious about this design flaw? I had an issue with my bump stop but i called KW and they took care of it when i sent in photos and emailed them a copy of my receipt from Evasive.
Old Sep 14, 2010 | 07:14 PM
  #22
spets's Avatar
Well the thing with the KWs is that it is easy to overtighten and strip the set screw on the spring perch, because the perch is basically made out of hard plastic.
I just got my set of V3s this weekend and installed them without any issues, but I could see it happening. One could always take the perch out, drill and tap for the next larger set screw size if this happens.
Old Sep 14, 2010 | 09:05 PM
  #23
chetly's Avatar
Your design flaw is the size of the set screw? I've been running my kw3's without the set screw being tight and they have not moved at all. The thing that I'm most annoyed with them is that fact that the perch is plastic and is a pain in the ass to turn when there is just the smallest amount of dirt in the threads.
But to answer your original question, the PSS9's are a good shock. I think better than the v3's. You can get the PSS9's revalved and have a better shock for less than or equal money to the v3's.
Old Sep 15, 2010 | 08:43 AM
  #24
spets's Avatar
Old Sep 15, 2010 | 05:29 PM
  #25
chetly's Avatar
Originally Posted by spets,Sep 15 2010, 08:43 AM
Old Sep 15, 2010 | 05:42 PM
  #26
INTJ's Avatar
Say guest, 4,000+ shocks better than 1,200 dollar shocks?
Old Sep 15, 2010 | 08:27 PM
  #27
JDMxDC2's Avatar
HKS Hipermax III Sport.
Old Sep 15, 2010 | 08:36 PM
  #28
spets's Avatar
Originally Posted by chetly,Sep 15 2010, 07:29 PM
I just thought that was a funny way of putting it the design flaw into perspective...
Old Sep 15, 2010 | 08:43 PM
  #29
g35s200o's Avatar
keep in mind when you buy coilovers in that price range, make sure they are rebuildable IN the states. Coilovers like HKS hipermax is only serviceable in japan
Old Sep 15, 2010 | 09:26 PM
  #30
You must be smoking something. No way the Pss9s are as good or better than the KWv3.
The KWs have amazing ability to absorb and stabilize over bumps during corners. The adjustablity of the Pss9s is a crapshoot. However with the KWv3s its a perfect adjustability with the ability to truly fine tune.
