IndyS200090 |
04-17-2019 12:35 PM |
Cooking Rear Brakes Through Track Use?
Some background on the car and its use:
- The car is a 2001 S
- Only mods are 4 brake ducts, per the DIY instructions from this site
- Hawk DTC - 30 pads front and rear for track use
- I flush the brake fluid every year with fresh Motul RBF 600
- I track about 4 times per year, usually tracking about 3.5 hours per weekend. Some weekends are more. In other words, I put about 15-20 hours or so of track time on the car per year
- The tracks I frequent are:
- Mid Ohio
- Putnam Park (In Indiana)
- Indianapolis Motor Speedway
I started tracking about two years ago, the spring after I purchased the car. In the middle of that season, I replaced the rear right caliper (Previously, was the factory one) Last year, I replaced the left rear (Previously, was the factory one). This year, I replaced the front right one (Previously, was the factory one). Up until this point, I chalked it up to age. However, my right rear is sticking once again. In other words, it's only lasted about 1.5 seasons of, I believe, pretty light track duty. Note that I don't have super sticky tires on either. I have Conti ECS tires all around, which shouldn't tax the brake system unduly.
The mode of failure is never total seizure. At least I usually catch them before they get to that point. They'll usually start to drag a bit and cause one wheel to get hotter than the other under braking. I also notice that they're harder to twist back in. These symptoms, lead me to believe that I'm cooking the square seal and that it's becoming stiff and non compliant causing the drag.
On a somewhat puzzling note: the front left is the factory one and still kicking after almost 20 years, no problems at all.
My main question is this: If I continue my current track usage, and I looking at replacing a each caliper every year or so or has my experience been atypical?
A secondary question is: are there any solutions to extend the life of the stock calipers given the extreme heat they see on the track?
