Cooking Rear Brakes Through Track Use?
The slide pins move very freely (I only lubricate them with silicone paste because, in the past, I found that the heat was cooking normal caliper greases into a paste) and the pads can move freely (I can easily move them with my fingers) within the bracket, if that's what you're asking.
To check more of the basics, is the slot in the rear caliper lined up with the post on the back of the inboard pad?
The shaving thing is a non-issue, you can order pads in the correct thickness or rotate through pads once you've spent fifteen minutes orbital sanding your first set of full thickness pads
Former Sponsor
As for killing the calipers - overextension and heat seems to be what kills them, I seemed to make my rear calipers last longer when I stopped trying to get every last mm out of my pads.
charlox5
11-04-2016 07:59 PM
Mike S.
04-09-2014 05:41 AM
beneintray
06-29-2011 03:37 PM
Greg W
07-15-2010 12:04 PM
