Sponsored by: Sake Bomb
DIY: Clutch Bleed (Gravity Method)
Old 07-18-2013, 06:18 PM
  #21
macr88's Avatar
Does anyone even make dedicated clutch fluid?
Old 09-25-2013, 05:02 PM
  #22
boony1968's Avatar
I've slowly been getting stuff knocked out since getting in S in July. Shifting was never great for such a low mileage car - '02 now at 27k.
First was the shifter re-grease. I had a ton of moisture in there and thought for sure there'd be a big improvement. Nope, just slightly better. A few weeks ago I changed the TF with Amsoil, again, only a slight improvement.
I changed the clutch fluid tonight. It old fluid was nasty, it even looked like 11 year old fluid regardless of miles. Took it for a quick spin, clutch was only slightly firmer, but no more knicks while shifting. By far the best 15 minutes I've spent on this car.
Old 09-27-2013, 04:01 AM
  #23
iamxpl's Avatar
also helps get rid of any air if you bleed it no? i did the same method as sillyboybmxer. just remember that method is for regular maintenance. well in my mind anyways. ill be flushing that fluid out quite often now. maybe every other oil change i will change the clutch as well just to keep it clean.
Old 10-19-2013, 11:04 AM
  #24
Shaybird's Avatar
Great DIY, just finished and the clutch feels great. Prior to this, the clutch wouldn't engage until 1 inch from the floor. Thanks for the help
Old 11-01-2013, 03:14 PM
  #25
rip_ej1's Avatar
Do I use this same method if I'm replacing my whole clutch master cylinder? I have a leaking CMC that needs to be replaced asap.
Old 11-18-2013, 10:06 PM
  #26
Static sean's Avatar
so the brake fluid is the same for the clutch as well?
Old 11-18-2013, 10:26 PM
  #27
Lord09's Avatar
Yes.
Old 12-22-2013, 07:32 AM
  #28
Blindeye_03's Avatar
A buddy just helped me do this. The fluid coming out of mine was slow though. But it didn't take long to flush the system. As for results my transmission feels a little less notchy.
Old 01-01-2014, 08:34 PM
  #29
toecheese's Avatar
Brake fluid will dissolve paint, so be careful not to drip any on your fender.
Old 05-01-2014, 06:11 AM
  #30
RHDS2K's Avatar
Thank you, i'll be using this today!
Quick Reply: DIY: Clutch Bleed (Gravity Method)
