eibach pro kit
i want to lower my car on the stock struts/shocks. and i wondering will i be safe on the eibach prokit as far as strut life? will the strut life be reduced? will i notice any handling difference. i like the 1inch drop because i still have my oem ap1 rims on but i want to get something simliar to ap2v1 rims. i wanna run a 255 in the rear and a 225 in the front tire width. would i be okay with that with this 1 inspring drop...also will i need anthing else? rear shaft spacers?. camber kit?
i have 255s in the rear and eibachs, everything is fine...
don't need shaft spacers or camber kit either...
Just be prepared to have to replace items. |
I've been good for 15k +miles on Eibach pro kit on stock shocks. Love them.
How much mileage do you have on your 2001 S? It's possible that your stock shocks/struts are already on their way out if you have more than 80-90k miles on them. I would look into some reliable coilovers...Like the Bilstein Pss9's.
i have 53k on my 01. it was babied its whole life too =]. i bought it at 51k. it is my dd also. are pss9 good dd coilovers?
Ya since your car is 8-9 years old, I'd think about getting a set of shocks to go w/ the Eibachs
I'm putting the Eibachs on my stock shocks and plan on them lasting for a while, but my car is only 10 months old so the shocks should be in perfect condition |
PSS9's are supposed to be one of the best DD coilovers on the market. Do a search on them. Virtually no bad reviews...Most reviews are positive.
Even though your car is 8-9 years old your shock/struts don't have enough mileage on them. This choice is up to you on whether you want to change your shocks/struts out along with springs. The only thing I can advise you of is if you do decide to change out both at the same time it would be best to change them out with a set(shock & spring combo) that have been engineered through R&D to work in unison with each other(coilover) no matter what coilover you choose to go with(along with the height adjust-ability as a bonus). My suggestion of a coilover for your driving style is the Bilstein PSS9's. |
