Sponsored by: Sake Bomb
hardrace front upper ball joint
Old 06-04-2018, 05:50 PM
S2000_916's Avatar
Default hardrace front upper ball joint
are they slotted like the oem ones?
Old 06-05-2018, 09:24 AM
B serious's Avatar
Received 1,250 Likes on 946 Posts
Try asking hardrace.
I doubt anyone has removed the boot. But I suppose turning the stud in all directions would tell you how they are jointed.
Or if someone can confirm they have an alignment dot...then you can pretty much assume they're physically similar to OEM construction.
why do you ask?
Old 06-06-2018, 01:20 PM
Carbon S2K's Avatar
Yeah they are mate and they are held in with a circlip, not pressfit like oem.
Old 06-07-2018, 10:38 AM
S2000_916's Avatar
why do you ask?
i ended up purchasing them. i took a quick look at them and didnt see a alignment dot and couldnt move the stud with my hand. i dont have them with me now so i guess i will email hardrace
im pretty sure they are pressfit like oem
Old 06-07-2018, 02:10 PM
B serious's Avatar
I'm sure they are pressfit.
But it would be pure insanity to re-press a ball joint into that arm without using a clip or some other method to ensure it stays retained in the bore.
Hopefully, they have a clip near the boot.
Old 06-08-2018, 09:56 AM
S2000_916's Avatar
Now you got me a lil worried , is your spc like that ?
Old 06-08-2018, 02:53 PM
B serious's Avatar
SPC's secure via a large threaded nut. They're not really a press fit. If un-bolted, I could probably pull the plates out by hand or by lightly tapping on them with a tool.
I re-pressed OEM joints into a control arm once and I tack welded it in place.
It looks like the HR joints come with clips, though. So no worries.
I'm assuming you meant slotted as in how the ball stud only has its full motion range (blue arrows) within a slot similar to OEM?
Or did you mean slotted like...they slide back and forth to adjust camber like SPC?
Old 06-08-2018, 08:43 PM
S2000_916's Avatar
yes exactly like that , i will report back after monday or so. i dont think hardrace is going to reply. my car is almost done just a few hiccups .
Old 06-10-2018, 03:38 AM
Carbon S2K's Avatar
Well I have these front and back and they just dropped in, I have a press but I didn't need to use it.
Old 06-10-2018, 06:48 AM
S2000_916's Avatar
Interesting
Quick Reply: hardrace front upper ball joint
