Help! Rear driver wheel not centered?
Hey guys,
picked up my 2005 about 3 months ago and noticed a problem with rear driver wheel. Car does not drive funny or pull in any direction.
I did some research and only seen posts about bent toe arms bent upper and lower control arms and cracked knuckles interfering with alignment or pushing a wheel in or out.
Issue im having is my driver rear wheel is literally pushed back towards the rear bumper. So pretty much not centered how it should be. Comparing it to the passenger side it looks normal from what I can see. Nothing looks “bent”.
I was determining wether to take it to a alignment shop or frame shop. Reason being is toe and camber can only be adjusted and don’t think those adjustments would move the wheel back and forth like the front caster adjustment, correct?
Any ideas of what hat could have happened. I was thinking maybe rear subframe shift? But would it be possible for the driver side to have only shifted?
thanks for any info or direction!!
Toe and camber adjustment will move wheel fore/aft position slightly.
Make sure your subframe is centered also.
If neither is the case, figure out what's bent. Its usually a spindle.
I did take a peek at the subframe and alignment holes, it seems to be right. Holes look to match up correctly. To shift the subframe it would have to take a hard hit no? other things to be noticeably bent or even broken with a hard hit?
I’ll take another look. I did notice a slight gap between a spot that differed from the passenger side but thought maybe that’s was just the way that spot was. I’ll try and post some pictures of everything when I get home. Maybe someone can see something I can’t in the pics.
Thanks B.
Lol I’ve never said thanks b in my life
Thanks B.
A
Driver side as you can see the small hole clearly and the big gap to the frame
Pass side you can barley see the small hole and gap is a lot smaller to frame
Pass side again
any help or advice would be appreciated.
Magazine thanks B for the replies earlier
Pass side again
JMAnonymous
01-29-2016 07:38 AM
TokeMadBowls420
06-08-2004 07:47 PM
