Sponsored by: Sake Bomb
HELP: Slight sponginess at top of pedal, can't figure it out
Old Jan 16, 2026 | 02:29 PM
  #21
CTRCAL's Avatar
When you had your brake fluid bled 2.7k miles ago, im guessing you had someone manually pumped the brake pedal during a bleed and they over extended the typical pedal travel and that caused damage to the brake booster and or master cylinder
Old Jan 16, 2026 | 02:31 PM
  #22
jadoos2k's Avatar
Originally Posted by CTRCAL
When you had your brake fluid bled 2.7k miles ago, im guessing you had someone manually pumped the brake pedal during a bleed and they over extended the typical pedal travel and that caused the brake booster and or master cylinder to fail.
It’s a good guess. But unfortunately it was me who bled it and I did a gravity bleed.
Even the last time I bled it with a 2 person, I made sure not to go too low for this reason. But still could be a failing master
limenuke
Jan 6, 2026 07:17 AM
DaveUK
Sep 16, 2023 12:24 PM
limenuke
Jul 19, 2018 01:23 PM
AP12001
May 30, 2006 08:39 AM
