How to stop sliding
Get you car to a performance shop for a track alignment, buy a set of sticky tires like Toyo, Khumo. or hoosier. Remember most times smother is faster. If your sliding you either let off the gas or feather it around the turn.
IDk if you have done much track driving before but just getting use to the car can be part of it. The overstear this car is know for can throw off a driver that is not use to the car. Tracking the S takes a lot of SMOOTH Throttle and Turn Input to get it where you want it to go, Also if you going to get tires and track the car again, I'd get some Dunlop Direzza Star specs. I normally use some ADVAN R comps for track driving, but ive been on the track with the Star specs and you should find a great improvement with handling. Good luck!
I dont track a lot, mayb a few times a year if any.
Oh, it's an 03. I did brake during the turn but after the turn it was when it started to slip. In track school, I believe they said if I started to slip (spin out) RWD= let go of gas not to gas it. That's what I learned.
PS:I have stock suspension and getting coilovers soon so I dont want to waste $120 on an alignment.
You need to get the car slowed enough such that by the time you're at the apex you're able to begin applying throttle and keep ON the throttle the rest of the way through. If you're driving the right line, and not carrying too much speed in, getting on the throttle will load up the rears and stabilize the car from apex to track-out. At S2000 power/weight, throttle-on oversteer isn't a big issue, you should be full throttle pretty soon after apex. Your line through the corner should allow you to unwind the steering as you gain speed between apex and track out.
Generally, ON the gas => UNDERsteer, OFF the gas or on the brakes => OVERsteer
Geez, this is performance driving 101, kids!
Regarding stock '03 suspension being "toast" by now, there's no reason it should be. My '01 has 130k miles and ~22 track days on it, suspension is A-OK.
Agree. That's why I was thinking I need new suspension and the tires are ok for now since I'm not tracking a lot. I believe stiffer suspension should control or at least less sliding on turns. Also the driving style, I'm more aggressive rather than smooth, after all I havent been to track more than a few times.
What do you have for tires now? I think you missed the point if you think that you DO need new suspension but the tires are "ok"! The point was, excellent suspension plus crap tires = crap handling. Address the tires first! They're a lot cheaper too.
As for stiffer suspension giving you more control, if your technique is off, stiffer suspension might give you MORE problems with traction.
Regarding tires, address that (depending on what you have for tires now) before suspension. IMO, for tracking a few times a year, stock suspension might be your best bet especially if you dd the car.
REgarding alignment, on stock suspension you'll want to maximize camber front and rear (should be about -1.5 degrees front, -2.25 rear), zero front toe, and ~.2-.3 degrees TOTAL rear toe (.1 - .15 degrees per side). Don't use the stock AP1 or the UK alignment, both prescribe too much rear toe, which will make the car more evil-handling/twitchy while at the same time hurting turn-in.
^The alignment you mentioned, is that also good for DD? I dont want to have a track alignment and eat the tires since I dont track it everyday.
Tires, I'm still on the Sumitomo HTR Z III. I may look for some star specs then. I wanted to get star spec after I get new rims, but I see the point where if you got shit traction, no matter what suspension you get you'll get shit traction cuz tires are the only things that touches the ground.
Not on par with Star SPecs, but certainly should be trackworthy.
If they have some tread left in them, I'd stick with them until they need replacing. Work on your line, and a more "slow in/fast out" approach to cornering. You should be on the gas soon after apex and shouldn't have to get off it until the next braking zone.
Jackie Stewart on cornering: "Don't put the power on until you know you don't have to take it off"
my 03 stock was pretty nice balance the rear will slide a bit but its predictable...
I think you need to do some more driving before you start messing with it
auto-x helps a lot
auto-x helps a lot
Jay I think its your tires. Dont add a rear sway bar, add a thicker sway bar to the front if anything. Stock suspension on the s2000 is really great. How does the wing feel?
