I can't lower my B uddyclub N+ Coilovers anymore
Ok so when I originally lowered the car I forgot that you had to adjust the height from moving the shock body, instead I lowered the perch below the spring which I think is messing with everything, the shock body is currently all the way to the bottom hitting the control arm and I have about an inch of gap on my ap2v1's.. So what are the proper settings for the springs, where do I have to adjust them so these will ride nice also.. If anyone knows of a thread on extreme coilover adjustments please send it my way, all of the threads Ive seen are on just how to lower the coilover from the shock body
You really need to take them all off and basically start over with proper preload and so forth. See my response here: https://www.s2ki.com/s2000/topic/877...#entry20714252
I would raise the front, remove the front two coilovers, adjust to the specs in that other thread, then reinstall. Then repeat with the rear. After they are all reinstalled you can play with the ride height as you see fit. Adjusting ride height while they are still on the car is pretty easy.
