kw v3 adjustment
kw v3 adjustment
Im having a little bit of difficulty trying to figure out how to adjust the bump on my new coilovers. i have the version 2 which is diffrent when it comes to adjusting the bump. the instructions they sent me are for the first version and im trying to put them on the recommended setting which is rebound for the front rebound 10 clicks and for the rear 12 clicks. now for bump its says front and rear is 0,75 turns open. that has me confused cause on my coilovers it has 0-5 which endup going 2 full rounds plus two more numbers. if anybody could help me put these to the recomneded setting for now that would be great
I have the same version. Just fully close the bump adjusters (turn CW looking up at the adjuster from the bottom of the damper, until you hit the stop). 0.75 turns on a 6-click range corresponds to 4.5 clicks, so open them (turn CCW, again looking up from the bottom) 4 clicks or 5 (your preference).
Of course, keep in mind these are just KW's recommended starting points.
Good luck.
Good luck.
smokeR
01-13-2012 07:46 AM
S2FARSI
01-01-2008 07:09 PM
Mr. Francesco
Member S2000 Classifieds and For Sale
09-13-2006 12:11 PM
