larger rear rotor suggestions
I'm getting an s2000 off of this site and it has Stoptechs in front BUT stockers in back. Is it possible to get larger rotors and use the stock caliper? The stock rotors look oddly small to me with the big Stoptech up front. Is there a functional advantage to upgrading the rear caliper? Do any aftermarket calipers retain the use of the parking brake?
Thanks in advance, Jonn |
The stoptech kits are specifically designed to be balanced even though only front rotor is larger. They have faq entry on their site for that specific question.
That said, on our cars rear rotors get hot due to lack of cooling. There are some kit options. Plenty of threads about this in this subforum. |
I would highly suggest the Urge rear rotors. It uses the stock calipers.
this is the baller solution that retains the stock caliper and e-brake.
J's Racing Evasive Motorsports | PH: 626.336.3400 Mon-Fri, 9am-6pm PST: J's Racing Rear Big Brake Kit Rotor Kit w/o Caliper - Honda S2000 Ap1/2 These are the domestic alternatives. Urge Flow Rear Brake Rotors | URGE designs Racing Brake https://www.racingbrake.com/S2000-RE...9-p/2145-k.htm And finally, the RX-8 conversion Sake Bomb Garage SBG Competition Rear Brake System (S2000, Rear RX8 Caliper Retrofit kit) - SakeBomb Garage LLC All 4 choices retain use of the parking brake. My preference would be the SakeBomb Garage kit. However, I ended up getting the Urge kit since SakeBomb didnt have their kit available yet. The J's racing kit ids over priced JDM bling. And Racing Brake has poor customer service/quality control. |
The Urge setup will also require you to shave down your pads or start with used pads that are worn enough to fit properly. That's my biggest gripe on the kit. I'd like to be able to have all new components go on the car without having to get creative.
Interestingly, there are quite a few straight-vane discs in this list. A straight-vane rotor does not pump air, and if not fed by an air duct can only radiate heat with more surface area than a solid rotor, but is not actually actively cooling itself with airflow. Also the width of the air gap also matters signifificantly, but no one seems to advertise the air gap (function of rotor width). There are a lot of solutions out there for the stock caliper - which is by nature narrow - (meant for a 12mm solid rotor). The RX8 caliper accepts a 20mm thick disc, which we take full advantage of :)
http://s20.postimg.org/rka7h47xp/IMG_0020.jpg |
Thanks for the replies. What year rx8 rear rotor and would there be any brake bias problems after the swap?
It's hard to believe no one has found a vented rear rotor that will work the oem caliper. Something with a oem application that is cheaper.
Assuming cut down pads and shaved bracket... |
Originally Posted by turbojonn
(Post 24201151)
Thanks in advance, Jonn the Sakebomb rear rx8 caliper kit does not - it's meant to be used with the Sakebomb AP racing front setup |
Originally Posted by //steve\\
(Post 24201083)
