legend twin pot calipers and accord v6 mt brackets
Hi guys,
I need some help regarding an upgrade I am doing right now. I have seen and researched a lot on this topic so I know for sure that accord v6 MT 2003-07 callipers fit the s2000 which is bigger and slightly heavier calliper with a bigger pad. I have checked that it may work with standard nsx rotor or euro type r rotor with a bit of shimming or grinding.
What I want to know is will a Legend twin pot calliper and accord calliper bracket work on the s2000 knuckle with euro type r disc or nsx or even standard? and because of the bracket I wont be able to use the legend pad I would have to use the 787 accord pad right?
I do not want to shell out 600 bucks on RB racing rotors as for me by the time they get delivered to UK will cost as high as a 330mm BBK hence I want to stay with oem size disc. I will be using Team Dynamics Pro race 1.2 17 x 9 wheels with the setup so clearance is not an issue.
any help will be much appreciated,
Thanks
Thanks
Since you are in the UK you may want to check out
http://www.freakyparts.co.uk/epages/...rake%20Kits%22
Local and decent priced 2 piece set up
I already have a Ksports 330mm kit on my other S. I want to keep this as much OEM Honda as possible.
lukeyboi89
05-15-2018 03:57 AM
bgoetz
02-28-2017 10:58 AM
