Max Negative Camber with 3/4" drop?
How much negative camber will AP2 camber adjusters allow with coilovers lowered about 3/4-1" and otherwise stock suspension?
I am getting ready to install some coilovers and and trying to determine if I need to install adjustable lower mounts to get the -1.5 to -2.0 camber I'm looking for. Cheers |
You should be able to get at least that much
Max stock should be -2.0 Front and -3.0 Rear or at least close. 1" drop should net you at the very least -0.5 additional.
I maxxed out at -2.4 in the front and I was lowered 1.5", so probably -2.2 or -2.3 at 3/4"
Originally Posted by RedCelica
(Post 24076348)
Originally Posted by Fokker
(Post 24076444)
...also wonder if having a larger FSB has anything to do with it :ponder:
(Post 24076558)
Originally Posted by Fokker' timestamp='1475592507' post='24076444
[quote name='RedCelica' timestamp='1475586799' post='24076348']
I maxxed out at -2.4 in the front and I was lowered 1.5", so probably -2.2 or -2.3 at 3/4" [/quote] I was able to. I currently have -3.0 front and -2.7 rear. I haven't asked to find out what the minimum is. They usually have trouble getting the rear set right, but I've always attributed it to needing to dial in camber and toe at the same time in the rear. At the time I had a Cusco FSB. |
