Megan coilovers
Hey guys,
Let's start the topic on there coilovers and share the experienes that people had with them. They are fairly inexpensive (compare to some JDM stuff :)) and apparantly get the job done. I have not heard any bad reviews about them yet. I is also rumored that they are assembled out of the same components that some more expensive coilovers are made out of. So, whoever has them please pich in! :hello: Thank you! |
There are two types
Track series (12k/14k) and Street series (12k/12k) |
Copy from the website: Track Series
For those who demand the absolute most from their vehicle |
Street Series:
Honda S2000 Model Number : MR-CDK-S2K Megan Racing Coil-Over Dampers are the ultimate upgrade to your track or street car. Featuring 32 Levels of damper force adjustment, full-height adjustment, these damper kits are then perfectly matched with front and rear Pillow Ball upper mounts for camber correction in most applications. The adjustment of the damper is as simple as can be with a built-in knob at the top of the damper mount for easy access. Simple adjustments can be made to tune to your style of driving and comfort level desired. Single-Adjustable dampers make suspension adjustments easy to tune whether you |
I have the track version, they are just as good as my apexi exv's.
i have a set sitting at home that i plan to put on this weekend. ill let you guys know how i like them.
Any of these coils will last longer than ur car.
Had the street version and now the track. I like the track version a little better, especially with the euro-spec alignment. :D
Is the track version significantly stiffer?
I mean, 14k in the back is not soft by any means :) |
Its a little stiffer than 12k, but just turn the knob and make it softer.
