Moddiction sway bar
Moddiction sway bar
so finally got my front sway bar and have run into some problems....
the bracket supplied does not even come close to fitting. See pics...
Kinda irritated I waited this long and spent a few hundreds bucks. Will be contacting moddiction as well.
can confirm. same as you. glad you found out. if i was under the car i would of blown a head gasket. lets see how long it takes to fix.
so im guessing you drilled out the holes to get the bolt to fit. and THEN found out it lines up like shit
Same here. I am guessing someone read the drawing wrong when they made them. The slot is the wrong width for the bolt size and the slots are cut in the wrong locations, so one has to be elongated. Very annoying to find out in the middle of the install process. Luckily, I have the ability to modify them. I also found that my bar appears to have the straight midsection a fraction of an inch too short, making the bushings push against the bent ends. That made it very difficult to get the bolts for one bushing to line up. I aborted the install at that point. I plan to offset widen the holes on the curved brackets in order to move the bushing away from the radius of the bent arms.
Also, on a minor note, the paint chipped off with the most minor of contact. Like dropping a small bolt on it. I'd guess it was not cleaned before painting.
I've been distracted by other things and have not contacted Moddiction yet to tell him of these supplier issues. I have worked in the manufacturing business, so, I understand the frustration of suppliers screwing up new batches of product. I would have hoped that a company that has been in business as long as ADDCO has would put out a better product.
From ADDCO's website: "Precision, quality and craftsmanship have been the hallmark of ADDCO sway bars since 1961"
I also noticed the same issues as you. Paint chipped extremely easy and the bar appears to be short. I will not be modifying anything. I paid money for a product that doesn’t seem to be worth more then a standard eibach sway bar at this point. I guess I will just wait another few months to get the issues corrected.
I gave up on the install. I thought about modifying brackets and such. Then I also thought about the money spent and the time I waited for it to be completely wrong. I’m not sure if I want to right their wrong. I’m completely capable of fixing the issue but it’s a matter of do I.
Former Sponsor
We are sending a spacer from a previous order over to manufacturer. Not sure why it would have been changed but unfortunately it looks like they did make an error with them. Once they get the correct spacer we can get replacements out.
The following 2 users liked this post by Moddiction:
Orleansjunky (01-05-2018),
RedCelica (01-05-2018)
