Need alignment suggestions: Eibach Pro Kit on stock struts with BBS LM
Background info:
AP2 with Eibach Pro Kit that have not had an alignment done since installing the springs, about 1 finger gap on the front and 1.5-2 in the rear (though the front right seems higher than front left at times...probably need an alignment)
BBS LM 17x7 +55 17x8.5 +65, though I reverse mounted the face so the offset decreased by 10-15mm, so actual offset is probably +40-45 and +50-55
BFG G-Force Sport Comp-2 225/45 and 255/40
Problem:
At current configuration, the rear will rub slightly on hard bumps, the front only rubs on really hard bumps
I probably should've gotten 215/245 tires which might help with the rubbing issue, but it's too late now and i do like the fat tire look.
Or I could not reverse the face and stick with +55 +65 offset, but i prefer how the reverse mounted face look.
So what is the best way to solve this? I know I need an alignment, but what camber settings should i target? Will I need to roll the fenders?
Problem:
relocation of rear bumper tab,if its rubbing there
