Sponsored by: Sake Bomb
New Ohlins DFV Road & Track Coilovers (HOS MI21)?
Old 02-19-2019, 02:19 PM
  #111
noodels's Avatar
Just got too set them up correctly for your own application,
Why,because race car
Old 02-19-2019, 02:40 PM
  #112
Car Analogy's Avatar
Received 1,304 Likes on 987 Posts
I agree about wondering about the base setup of the test car used for this revision. Tires, sizes, swaybars, etc.
Here is another possibility. Someone hears oversteer, so they decide it needs softer rear spring. Then later tbey discover the real issue is riding bumpstops. So they make the other changes to give it more compression stroke. But then either no one goes back to rethink spring rate, or maybe they already ordered a bunch of softer 7k springs, and they it was too costly to change it.
Old 02-21-2019, 08:00 AM
  #113
JK'sS2k's Avatar
Idk this logic seems to make sense to me. They mentioned they were able to achieve an additional 20mm compression stroke with the 7kg spring and increased preload when compared to the 8kg spring with less spring preload. Because they did not want to raise the car height anymore, they lowered the shock body to compensate.
The problem they found with the rear is the limited compression stroke and oversteer tendencies. Increasing the front spring and decreasing the rear spring address the oversteer tuning and the 20mm addition to compression travel while preventing hitting the bump stops are associated with the lower spring rate and increased rear spring preload . If droop travel is an issue I guess a helper spring in the rear would help as well but I don't think they would have the room.
Am I missing something??
Old 04-03-2019, 05:27 AM
  #114
Ajval79's Avatar
I just ordered a set of Ohlins coilovers with 12/10k springs, really looking forward to putting these on and getting them dialed in. I'm currently on Eibach pro springs with stock shocks so this should be a huge improvement.
Old 04-04-2019, 08:33 AM
  #115
Sincereone's Avatar
I got my Ohlin coilovers installed a week ago and they feel great. I switched for the 10k/8k springs with Sakebomb rear lowering cups. I’m running a whiteline front sway bar along with the rear driveshaft spacers and front steering rack spacers on my Ap1. I’m staggered also 17x7.5 225/45/17 front 17x9 255/40/17 rear.
Old 04-04-2019, 09:32 AM
  #116
JagoBlitz's Avatar
And? First impressions?
Old 04-04-2019, 10:34 AM
  #117
Sincereone's Avatar
It’s a really nice. Billman installed and set it up. I got the preload specs from Sakebomb garage. Def has faster turn in now and bodyroll is reduced. I’m still playing around with dampening settings but overall I’m really liking it. I have a a lot more confidence pushing the car now as it stays planted and easier to predict.
Old 04-22-2019, 09:31 AM
  #118
BootsS2K's Avatar
FWIW I just had the HOS-MI21 stock kit installed on my S2K last week, While I don't track the car, the car feels fantastic on the street and the ride over stock is much improved (lowered ~1")
Old 04-22-2019, 10:38 AM
  #119
cenix's Avatar
I noticed Sakebomb Garage was advertising the new MI21 kit with 10k/8k or 12k/10k rates with their lowering fork and remote adjusters for the rears.
SakeBomb Garage (06-20-2019)
Old 06-18-2019, 08:40 PM
  #120
andrewhake's Avatar
Originally Posted by Barnburner3
To add even more confusion:
Yeah I have it on good authority that 2 way DFV could be happening this year. (Oh my yes).
Quick Reply: New Ohlins DFV Road & Track Coilovers (HOS MI21)?
