Newbie Needs Suggestions - Pads AutoX and Light Track Use
I concur with all of the above, except I think they do fairly well on track as well. AX6s rock.
What if I'm running a 200 treadwear tire? I have Rs4s.
buy carbotech xp10. Ax6 will fade fairly easy with a 200tw tire and a somewhat fast driver or a brake heavy track.
Don't waste time trying to track with stoptech Sport either. They are good for daily, autox and spirited driving, but not much outside of that.
You leave out how much experience you have doing AutoX or HPDE. Based on your original post guessing it's minimal? Once you get more time in, there's not much of an intersection between pads that are good at Auto-x, HPDE, and street for this platform. Toss in the fact the stock S2000 brake system is bit undersized to begin with it further exacerbates the ends of the spectrum with pads.
Fore reference I track and drive on the street my G-Loc R10 but it's only street driven infrequently on weekends and to / from track days. If I had a more frequent street use I'd swap pads and rotors. My advice is to start with Stoptech Sports. They're a jack of all trades, master of none. If you do more Auto-X or HPDE track time then adjust.
The rears will get hot and reduce friction/braking force with Stoptech Sports, but it's pretty obvious when it happens. Your braking distances will increase slightly, and you'll be getting more into ABS as the bias shifts forward. Same type of things you need to think about when tracking a street tire that's going to generally suffer from heat sooner than an R-comp etc.
I'm in the advanced/instructor groups at HPDEs, so if you're a novice or intermediate, you're probably going to put MORE heat in, as you're going to be overslowing the car and likely having more brake events. So just keep in mind you'll be getting them hot sooner, and adjust your driving to suit, but based on my experience, they'll handle it.
I think some 2" cooling ducts in the rears will probably keep things roughly under control back there to even things out, but I'll have to fab some up and test it out.
Powerstop just came out with "trackday pads" for the S2000.
I'm kinda curious about them. They're massively cheap (like $140 for the whole set). Not as cheap as Stoptech Sports. And probably not as streetable. But likely more bite and better high temp characteristics. The Stoptechs have ok initial bite...but its not anything to write home about.
I do like the huge amount of bite that track pads have when driven on the street. But...I always feel like I'm wasting an expensive pad. I am currently using Carbotech XP12/10.
If the Powerstops work well and bite like crazy...for $140.... I'll likely just leave them on all the time.
Kind of like shocks, you need to figure out what you like and most importantly what you don't about your current pads and go from there. If the pads that are on there are above 60% I say use them for your first event.
if you need new pads, they fall in two camps. Street pads you can use on the track and track pads you can use on the street. I recommend staying in the first category while you learn the car.
My favorite pad in that group is stoptech sports. Think of them like stock +. I am actually running them now as I figure out what my next track pad will be. They are as streetable as stock except for more dusting. Have a bit more bite, and definetly handle more heat. Plus they are cheap.
Nate Tempest
02-02-2018 10:48 AM
arctic_blue83
09-28-2017 09:17 AM
