The 17x8 +50 pf01s clear the kit.
Originally Posted by clarkster009
(Post 21213756)
So the +45 not? Do you have pics of the +50 with the kit? Thanks |
Mr. Sideways had some pics...it cleared by a few mm. If the +50 clears, the +45 probably clears by 5mm more. But I am saying there is no need to go to a lower offset if the +50 fits because it will make for an easier fitment without rubbing.
Any of you guys that have the kit...I was wondering if you could do a huge favor as I was looking for some measurements on the hats and rotors, as well as the mounting bracket. Specifically, I wanted to know the rotor hat's bolt pattern (for example the Wilwood is 12x8.75") and the hat offset (Wilwood's is .54").
I was also wondering about the caliper radial bracket. Is the bracket 130mm or 152mm? For example, the Wilwood is 152mm/5.98". I have affixed drawings if it helps: http://wilwood.com/i...Mount-bm-lg.jpg http://wilwood.com/I...5lug-lg-dwg.jpg I would appreciate it a bunch. -Kevin |
Anyone running PF01s in 17x9 that clear this kit? That would be ideal for me. Haven't seen anything though... :(
FYI, I attended the PRI show in Orlando last weekend. I spoke with the Stop tech people there and they informed me that for this summer they are coming out with a new caliper that will be in size comparison with the wilwood dynalite calipers to make them more friendly with wheel offsets.
(Post 21224115)
I like the look of the Pf01 with the lip...with the +50 there isnt... Which size/offset could have lip and also fit the stoptechs?? |
The 17x9 js the only one w the lip. The point of the other ones is to bbk friendly. The lip looks good but is a detriment. The only one that may clear is 17x9 +35.
(Post 21225731)
If the 17x9 +35 could fit the stoptechs... it would require fender/bumper modification, right? |
Add another to the list:
Advan RGII 17x9 +45 Huge amount of clearance... https://img836.imageshack.us/img836/2433/imageoyx.jpg https://img28.imageshack.us/img28/8085/imagegwd.jpg |
