Ohlins DFV review
As far as s2ki vendors go, I have to say Urge design is one of my favorite vendors. They are a relatively small company because they deal specifically with s2000s and actually perform R&d on their products but they are always extremely fast to reply, extremely knowledgeable and very friendly. I will be testing the urge DFV vs kwV3 suspension, the stoptech rear BBK vs OEM rear brake setup vs urge rear flow rotor BBK and the berk exhaust vs urge scavenger exhaust with a complete and detailed write up when the next track season arrives in approximately 4-5 months (give me some time to write up the specifics once the data has been acquired). Stay tuned for the results (this will include lap times, dyno charts, heat differentials etc.)
I don't post much but be on the lookout in a few months when these writeups will be published with the help of Urge Designs
Originally Posted by andrewhake' timestamp='1448058075' post='23808667
What spring rate are you running?
My thought on the helper is right now when the car sits the ground it's sitting at about 3/4 inch compression of the shock. Since the spring is taught on the shock that means once the car rolls more then that amount it's going to lift the inside tire with no resistance since the shock will be at full extension. I'm thinking use the helper spring to put the shock further into it's compression travel when sitting static. It will reduce overall travel and thats the downside.
Thanks.
Originally Posted by Mrsideways' timestamp='1448378197' post='23811440
[quote name='andrewhake' timestamp='1448058075' post='23808667']
Thanks.
[/quote]
I'm curious too, looks like I may have to send mine in for service so it'd be the perfect time to upgrade the springs.
O-turn
05-03-2011 03:02 PM
