Sponsored by: Sake Bomb
Ohlins Road and Track Review
Old 08-16-2013, 07:44 AM
  #21
BigDRichy's Avatar
Did you put any spacers in?
Old 08-16-2013, 05:56 PM
  #22
JayPizzle's Avatar
Please keep us posted. I'm deciding between these and tein src evasive spec
Old 08-17-2013, 03:26 PM
  #23
sillyboybmxer's Avatar
very nice pics
anyone have first hand experience with these and KW's....thinking of ditching my clubsports for these or AST's.
My problem i 'think' is springs not being stiff enough .....when I get my clubsports set to where it feels good in the smooth corners,..i take a turn with bumps and it skips. I know the rates are about the same but the single adjustable seem better to the average user.
Old 08-22-2013, 12:44 PM
  #24
Sponsor
Urge's Avatar
Originally Posted by sillyboybmxer
very nice pics
The DFVs have a Super High Speed path specifically for that scenario, the tire can get up and done fast to reduce skipping. All other shocks have 2 oil paths for high and lowe speed, DFVs have a 3rd Super High Speed path which is basically a 2 way blow off valve.
This where the name comes from Dual Flow Valve (DFV), 2 way Super High Speed (Blow off) path for Fast Bumps or Bumps at High speeds, car simply stays settled..
__________________
Old 08-23-2013, 09:59 AM
  #25
Croc's Avatar
very nice pics
what spring rates yoir clubsports?
so you say springs are too soft but but skips on bumps?
i would say missconfiguration.
Ohlins should be good but i personally addicted to separate adjustability of bump/rebound...
Old 08-23-2013, 10:22 AM
  #26
I have the stock springs on them. So 572lbs I believe. I am no pro at this and can only experiment with what is said online. But if I get it so the body roll is how I like...very little(comptech front sway on full stiff and 255s)...it will not handle bumpy corners well so I assume my rebound is too stiff. I am set at 3 from full stiff on bump and 5 and 7 from full stiff on rebound. I know this isnt a setup thread but those kw's are being sent back due to the rebound adjuster cap\seal coming loose and the o ring not sealing on top so I am probably gonna order new shocks and just sell the kw when they come back.
Old 08-23-2013, 10:24 PM
  #27
Croc's Avatar
5-7 rebound sounds very stiff - this is probably why the car bounces.
also adding huge sway creates more difficult environment for the dumper - sometimes the dumper gets overwhelmed.
Old 08-24-2013, 12:28 AM
  #28
macr88's Avatar
When I had CS's I ran them at two sweeps comp and rebound at 4-6. No problems with small bumps but larger bumps were an issue and it wasn't because they were too stiff.
Old 08-24-2013, 03:42 PM
  #29
andrewhake's Avatar
Me too. But I already have the Evasive SRC waiting to be installed and I am considering buying the DFV as well so I can try them back to back, but the problem with that is if I have both I will just want to sell them both and buy the Ohlins TTX.
Old 08-24-2013, 04:01 PM
  #30
macr88's Avatar
You have your answer.
I would still buy both so you can see the difference
