Sponsored by: Sake Bomb
Ohlins Road and Track Review
Old 08-24-2013, 04:54 PM
  #31
andrewhake's Avatar
Originally Posted by macr88
Originally Posted by andrewhake' timestamp='1377387775' post='22743113
[quote name='JayPizzle' timestamp='1376704609' post='22729137']
Please keep us posted. I'm deciding between these and tein src evasive spec
Me too. But I already have the Evasive SRC waiting to be installed and I am considering buying the DFV as well so I can try them back to back, but the problem with that is if I have both I will just want to sell them both and buy the Ohlins TTX.
You have your answer.
I would still buy both so you can see the difference
[/quote]
Damn it why does this solution make so much sense?
Old 11-26-2014, 08:53 AM
  #32
kotsapas's Avatar
any track impression on these?
Old 11-26-2014, 10:01 AM
  #33
S2KHANG's Avatar
I'd like to know as well. Since the spring rates are 10k front, 8k rear, ootb, I'm assuming this be a good set up for non stagger.
Old 11-27-2014, 08:24 PM
  #34
tcjensen's Avatar
I'll speak for a couple local guys on them, though I am on KWV3's myself. The DFV's are great on track. One guy is running the 700f/571r and the other is the OTS 571/458 (?). They are both very fast cars. Don't seem to be necessarily faster the KWV3 cars, but I would imagine they ride better, as well as being easier to dial in (1 adjustment instead of 2). The spring split is great for staggered setups, and requires less bad adjustments to balance.
Old 11-27-2014, 08:25 PM
  #35
tcjensen's Avatar
Old 07-17-2015, 06:13 AM
  #36
kotsapas's Avatar
Has anyone tried this suspension with semi slick tires?
Will the pre supplied springs be sufficient?
Old 08-02-2015, 09:10 AM
  #37
Sponsor
Urge's Avatar
IMO, you will need a little more Spring for Slicks Id move to 13/10 KG/mm.
We can help with that upgrade..
Patrick
__________________
Old 08-03-2015, 04:31 PM
  #38
Chugs's Avatar
I've had the DFVs for almost a year with 700f/571r, and about 7 track events on them on 255RS3's. They ride amazing on the street, better at absorbing little imperfections in the road. On the track they really hold their own, and each click of adjustment really changes the car's behavior. I usually run 6 clicks from stiff in the front and 8 in the back, depeneding on track and condition. I would not say that these make for a faster car than KWV3's, but the build quality is superior.
But when it comes down to it, speed is not everything when it comes to buying parts, as it's just as important to buy parts that will LAST, and these sure seem like they will.
Old 09-16-2015, 04:37 AM
  #39
kotsapas's Avatar
thank you for your responses..
I just ordered these (yesterday)..
I plan on racing with these on the track with very sticky semi-slicks.. i.e. Direzza DZ03G and Federal FZ201
I plan on changing the springs on a similar setup to Chugs..basically I am going to use the supplied front springs on the rear and and get a fresh stiffer set for the front..around 12kg/mm (672 - 728 lbs/in)
My question is, don't these coilovers need revalving with this spring change? or it is very near to manufacturer specs and its ok?
Urge design's input on this?
Old 09-16-2015, 07:30 PM
  #40
B serious's Avatar
Received 1,250 Likes on 946 Posts
Why not try the stock springs first. Then move to stiffer springs if you feel you need them? 10kg/8kg is a tad soft for R-compounds/semi-slicks. But there's no sense in blindly changing the springs.
