S2KI Honda S2000 Forums (https://www.s2ki.com/forums/)
-   S2000 Brakes and Suspension (https://www.s2ki.com/forums/s2000-brakes-suspension-249/)
-   -   Is this okay? (https://www.s2ki.com/forums/s2000-brakes-suspension-249/okay-805879/)
stwokayyy Jul 28, 2010 04:18 AM
Is this okay?
Hey guys my car which came with pss9's did not have helper springs, so when I jack the front up the springs are loose. my question is if this is okay or not, if not what are some alternatives I can do to fix it? helper springs? another set of springs with highier spring rates(I wouldnt mind this option)? I dont really want to highier the car since it sits perfectly.
cfap2 Jul 28, 2010 08:55 AM
the springs are supposed to play on that coilover because there is not bottom bracket to adjust height. Do you have a helper spring? If you get a longer one it will help.
stwokayyy Jul 28, 2010 01:22 PM
I dont have a helper spring will it effect the ride height if I put one on?
cfap2 Jul 28, 2010 02:08 PM
You will have to readjust the perches. but Im sure you can put it as low or as high as you would like. The only problem is that as you lower the car you lose stroke on the shocks.
© 2026 MH Sub I, LLC dba Internet Brands
