Sponsored by: Sake Bomb
Origin Fam offset bushings squeak like crazy
Old 05-16-2019, 08:43 AM
Nfsryder's Avatar
Default Origin Fam offset bushings squeak like crazy
Hey guys got my delrin offset bushings from Origin Fab put into the front upper control arms about a month ago. They've been quiet up until about a week ago when I heard a slight squeak going over bumps. It's gotten worse since then and now it literally squeaks over every bump/uneven road surface. Even just driving in my underground condo garage going 2km/h it squeaks and creaks like wooden floors in a 100 year old house. I've heard and read that delrin should be self lubricating so what's causing this squeak? Is there anything I can do without taking anything out?
Old 05-19-2019, 08:06 PM
I Love My S2K.'s Avatar
How hard was the installation?
Old 05-22-2019, 11:12 AM
Carbon Blue's Avatar
how high did you torque these too? It was mentioned that the OEM torque spec is too high for these.
Old 05-22-2019, 02:17 PM
noodels's Avatar
marine grease used ? could also intsall grease nipples
Old 05-22-2019, 04:53 PM
Charper732's Avatar
Did you install the washers on the outside that ride against the frame gussets? install grease nipples. I have been running the offset bushings for over a year. Other than the initial grease, I have not added any and mine never squeak.
Old 05-24-2019, 04:10 PM
Nfsryder's Avatar
Tbh not sure cause I took it to a shop to have it installed. Guess I should probably loosen it and retorque it.
Yeah washers are installed in the same configuration as the reference pics on the Evasive website. I'll look into installing grease nipples but I thought these wouldn't need regular lubrication since delrin is supposedly self-lubricating.
nigoape1
09-14-2010 08:41 AM
BulldogS2
06-04-2006 07:54 PM
S2K TX
05-10-2005 07:54 AM
AndyS2
10-26-2003 07:12 PM
Quick Reply: Origin Fam offset bushings squeak like crazy
