Passenger side front rotor has groves
11500 Miles on 2006 , no track or auto cross time : front passenger rotor is developing grooves on rotor while the remaining three are wearing evenly
ANY SUGGESTIONS
ANY SUGGESTIONS
Um, severely worn pads on that corner? Worn down to rivets causing groove.
Why that one corner only, most likely caliper slide pins seized.
Remove caliper, clean up or replace slide pins. Lube properly.
New rotors, new pads.
Slide pins
thanks for the tip, it was super easy removing slide pins , cleaned and back in action , my pads didn't have rivets and after a few miles the so slights groves are fading away
If the grooves are fading away after just a few miles, then they weren't really grooves. They were deposits from the pads. Grooves worn into the rotor would take thousands of miles of street driving to wear away, if at all.
