Question about Ohlins DFV V2 springs.
Wait...so why do you think they're 10K/8K?
Are there spring part numbers or identifiers in the manual?
48010-35 & 48010-19 are the part numbers in the manual
48010-31 & 47010-23 are what I received.
Are you sure you really want the new spring rates?
I would probably rather use the ones you got, but it all depends on the rest of your setup.
If you mean kg when you type k then yes that's correct, the ones that should have come standard with your kit are 11.2 and 7.14 kg/mm though.
Yeah probably a good idea to confirm what you got and maybe why as well.
The "updated" rear shock doesn't have any more stroke though it's the same, they only added more preload which is what gives you more compression stroke.
It's a pretty long thread but you should read it if you haven't already https://www.s2ki.com/forums/s2000-br...s-mi21-1187494
